Pico 4-pin breakout lead Deutsch (TA193)
The Pico TA193 connector breakout lead enables you to take voltage readings from the numerous sensors and actuators in the engine compartment. Simply connect the breakout lead into the existing cable loom, and then connect the 4mm banana plug of your test lead to the breakout leads banana jack. The ...
